I bought a Speedster 200 with twin 155hp Rotax Engines...it runs great, but I'm having some weird power delivery issues.
The boat pulls to the right whenever I have the RPM's matched. At full throttle on both sticks, it pulls fairly hard in that direction. There is no difference in sound of engines, or throttle response, but even at low speeds, if you punch just the left engine, it seems to pull harder than when you punch just the right. I checked both pumps and they are clear. Any thoughts on this?
On a separate note, anyone know where I can find a wiring diagram for the instrument panel in this boat? The Speedo doesn't work, and the Tach's have been flaky. I want to make sure the grounding is correct, and check the other signals with my multi-meter.
Thanks
Thanks
