I have an 04 Speedster 200, 310hp. Was running fine when i parked it up last summer, took it out to try yesterday, the old battery was completely dead so i fitted a new one, attached the key, it didn't beep and only the left engine will start, when i push the button on the right it does not do anything. I have checked the fuses under the dash and both fuse boxes in the engine bay, all of them were ok. There doesn't seem to be any wires corroded and the boat has only ever been in fresh water. none of the lights or gauges work on the dash apart from the ignition lights on the left. Is there anything else to try or any hidden connections, fuses or relays i could try, my nearest dealer is booked out for a while.
Thanks in advance.
Thanks in advance.
