I have a 2004 Sea Doo GTX that stalls and seems to go into a limp mode after running for 10 to 20 minutes at 3000 to 4000 rpm.  When coming back into Marina and slowing down to idle below 2000 rpm it will stall and run a continuous beep, even after pulling the key.  If you pull the key and let it sit for about 5 minutes it will restart like normal.  I just purchased this year and previous owner had a new battery installed before I purchased.  Runs great at higher RPM but also seems to go into this stall mode after coming back to idle.  When you first start it up from cold it does display "Maint" on the screen.  Any thoughts on what could be causing the stalling after a nice run?
