Needs some help. I have the #3 injector not getting fuel.. put new injector on still nothing. Put the new one on #2 works? Thinking maybe ground or bad plug?
hello you need to check for injector pulse from the engine control module hook up a volt meter across the injector [dc] and crank the engine . compare to the other known good injector . hope this helps good luck
