kirbyepsilon
When I try to start my 04 gtx Wake and it only clicks at the relay and nothing else happens. The motor doesn't try to turn. I tried tap starting the relay and dont get a spark. I took out the starter and hooked it up to the battery and tested it. The starter stared spinning off and on and then began spinning freely. I hear starters can get locked up, And once starters lock up, and get freely running, it is a sign that the starter is beginning to go out. Is that true ? could it be the relay ( i replaced the relay with in the past 3 months ) Thanks for the help in advance !
