The jet ski will beep for a couple of seconds while runing but there is no error on the display. This has happened while running around 5000 RPM and even when it was in idle mode. It comes every once in awhile. The jet ski does NOT go into limp mode. I can still excellerate over 8000 RPM after the alarm goes off.
Someone suggested changing the Oil Tank Pressure Switch as many of those are failing.
Any other ideas? I thought of taking it to a dealer, but there may not be an error code on the computer either.
thanks for any help
thanks for any help
