Hi all yesterday i hooked up me battery backwards no smoke no blown 5 amp fuses but also all dead i found out what i did but now it gets worse. I have 2 machines so i swapped the master cut off relay module with the other not realizing i had shorted it out now both machines dead, but there is light at the end of the tunnel. I can ground the black & purple wire as the master cut relay & all works fine so did i fry a diode in each mpem(s) & are they reparable. I am an auto mechanic & if there is info out there i can do it does anyone have any info on this modle????
