2004 GTI LE bad MPEM
TheGator7.1
New member, First post:
Found out the hard way you are not supposed to use Quick start charger or jump start from a running vehicle. Blew my MPEM. I am going to attempt the Diode replacement. $500+ for new MPEM, $350 for used, $130 for aftermarket. $6 for diode. I carefully exposed the bad diode thanks to other posts info. Now awaiting arrival of replacement. Will attempt to remove and replace diode. Thanks to all who posted about their similar problems. Will post result.
Diode exposed by careful use of dremel and hand picking with probe and razor knife.
All done. Re-potted with 3m DP270 potting compound. $12 in clear or black. I used clear. Practice with it. Designed for use with $70 applicator, but just like any 2 part epoxy, you can mix it yourself. Of my 3 batches (2 coats for component side, 1 for solder side) one was perfect with nice clear result, one was clear, but stayed tacky because I was not exact with my ratio (1:1), and the last was fine except I mixed too vigorously and it retained micro bubbles which left an opaque finish. All in all for $19 dollars and a little patience, I am happy.
