levani041491
Good Morning , just bought 2003 Utopia 240 EFI ( I guess new style) that was seating for 3 years , boat started and was running fine on the hose So we Sent it to have Complete seats/interior redone . 2 weeks later got it back but would only run on carb cleaner . I changed water separator filter/start plugs , still would not start so I took apart Complete fuel pump tank and was full off Gel looking fuel and oxidation so I cleaned everything and assembled it together . boat started on its own , started running Great , next day I tool it out in the water , ran fine for 15 minutes then I felt little misses and then is started popping backfiring from exhaust( light ) but would partially clear up after 4500-5500 rpms then Bang and it turned off and would not crank but I could spin the motor by hand , found negative terminal gave little wiggle and it started right up with running rough misfiring , started heading home and 2 miles later out of nowehere everything cleared up and started ruining Great like it never ran ( sounded like nice 4 stroke) came Close to Bridge dropped speed to 5mph ( no wake ) and when I try to accalarate from 1000rpms boat did not wanted to rev up at all , barrley running 800rpms and popping exhaust and misfiring and stalling . called tow and he got us home . at home cranking it would backfire and try to spin backwards so broke complete starter and 1 tooth I
I checked
New starter ( cranks great )
fuel Pressure its in spec
changed Map sensor top of the intake ( new)
checked fuel, no water fresh 89 octane ( filled it up before takeing it out )
new Spark plugs where covered in oil so I burned out and they spark fine
checked spark in all 6 cylinders and they all fire fine
FOUND PUDDLE OF OIL BOTTOM OF THE INTAKE ( dont know how it got there)
Got boat to start and Idle somewhat fine 15 minutes or so ( on the hose) after cleaning oil and spark plugs but when I move leveler forward it will start pupping puffing and wont rev past 800 rpms , I can move throttle WOT , I see throttle plate fully open wont rev just making lots of noise from intake and popping from exhaust like slow motion anti lag system
please advise me if there is else something I can check , i have DMM and power probe and all other tools that mechanic could have
I checked
