Ill give to a tip, if you take it to a dealer befor you buy it and get them to hook up the b.u.d.s system up to it you can see the maintinace history like weather or not the 10hr service was done on it and also how the boat was drivin, Its shows you a bar graph with diffrent rpm ranges from 0-redline and a % for each range so mine i know it only hit 7000rpm for .06% of the total hrs on the boat witch was 70. um hope that makes sence. LMAO i think that % has changed a little since ive had the boat. and also do a compression test on it.
what the buds system can do all summed-up!!! rpm profiles, throttle position, history, faults, diagnostics and can go thru auto-test of every sensor and feature on the ski/boat... i gotta get me one some how???? also have a good look in the intake grate and the pump and make sure the wear ring and impeller are in good shape. I did all this last january when i bought my boat
