when you say peep hole. the hole on the side of the boat correct. is there anyway to blow air to get unclogged or is there something else they do to unclog a system when for some reason gets clogged??
There are a lot of holes in a boat. Let's be clear what we're discussing.
The pee hole is small, about the diameter of a pencil for Mercury and a bit smaller for Rotax. Every one I've seen is mounted on the back (transom) of the boat, not on the side. This is true even on jetskis. The holes on the side are generally fuel tank vents, bilge pump outlets, etc. and are larger in opening than the pee hole. You don't normally have water coming out of the side holes, but you should ALWAYS have water coming out of the pee hole if the engine is running.
You should have a steady stream of water coming out of the pee hole when the engine is running. The water should be cold when the engine is cold and warm when the engine is warm, since the water coming out will have passed through the engine block (but not the exhaust system, it's taken off the water cooling system ahead of the exhaust).
Find the pee hole. Start the engine. If you don't have water coming out very soon, shut off the engine and start looking for reasons why you either aren't getting water into the engine or aren't getting water out.
If you do have water, its temperature should track that of the engine, particularly the heads. The two heads should be the same temperature at all times. If one is cold and the other hot, you have a cooling system blockage.
Go see what your pee hole water is doing, and then report back.
