As the title says, im trying to fix a seadoo throwing P2620 and P1120.
Codes are TPS value not correct, and Throttle positions calculated from TPS 1 & 2 are not correct.
So I already swapped out the throttle trigger and the throttle body for known good ones. Reset TPS with candoo pro but same problem.
The ski is hard to start without holding throttle lever half open. Then it starts and goes immediately into limp mode.
I can see the TPS value go from 10 to 100 in candoo when moving the finger throttle.
At this point im inclined to believe it's electrical but dont know where to look. Put a new battery in it too, cleaned up the grounds. I dont want to guess throwing parts at it because an ECU wiring harness is $800 here.
After picking around for a bit it also threw P0122 and P0222 whis is something called 'TAS' short to ground.
Any thoughts?
Any thoughts?
