JACKOMO
Hey Guys I was hoping someone can guide me in solving my DI issue.
Seadoo starts no problem runs for 5 seconds, revs up for 1 second and stalls. If I play with throttle I can keep it running up to rev limiter.
I have done the following already....
Replaced Fuel Pump with good ebay one
Replaced Fuel Filter
Cleaned Raves
Cleaned Reeds
New Spark Plugs
Swapped Fuel injectors
Swapped Ignition coils
Replaced Battery
Replaced Rectifier
Swapped MAP Sensor
Reset TPS
Swapped Rave Solenoid
Cleaned grounds
Compression is 135 psi and equal
I have Candoo Pro but only things showing up were diagnostic cap and wrong pattern sensed on encoder.
The only thing I can think of is swapping air injectors and TPS Sensors with known good one.
Any other ideas? THANKS
Cleaned Raves
Cleaned Reeds
New Spark Plugs
Replaced Battery
Replaced Rectifier
Swapped MAP Sensor
Reset TPS
Cleaned grounds
