2003 Islandi 250 Opti Won’t Spool up completely
The tach doesn’t work on the boat but she is not reaching full revs. Struggles to get on plane and isn’t nearly s fast as she was. I changed spark plugs in my initial attempt to sort it out. What else should I look at? TIA
Start with a compression check. All plugs out, WOT. Are you sure all plugs are firing? (Is each plug warm/hot?)
Since the tach is sort of a diagnostic tool, can it get replaced? RPM is an important data point.
