JMac69
Based on what I found searching threads here I believe the procedure to replace the oil cooler is this:
1. Take the 7 bolts out of the intake manifold.
2. Disconnect a few plugs and air intake.
3. Tilt manifold forward out of your way.
4. Pinch off coolant lines and remove clamps.
5. Remove 4 bolts on the oil cooler.
I wanted to see if I could find answers to a few questions related to these steps.
Step 1. This is pretty straight forward.
Step 2. For the plugs do I remove: 3 ignition coils, CTS, OPS, CAPS, KS, CPS, Magneto, EGT, and plug on starboard side exhaust?
Step 3. Does tilt forward mean towards front of the engine or towards port side of the boat? Are there intake manifold gaskets I need to watch for?
Step 4. What is the best way to remove the original Oetiker clamps on the coolant lines in a tight space?
Step 5. This also is pretty straight forward.
Replacement: If I mess up a gasket, O-ring or other consumable part, where do you suggest I find replacements as my local shop won’t stock parts for this year boat anymore.
