2003 GTX Help
Reveren00
I have a 2003 GTX 4tec. I changed out the MPEM and it started right up and ran fine. But when I hit top speed I had beep and the light blinked red my the exclamation point. But it still ran fine.. Can someone tell me why its beeping? Thanks
Not without more information. Press the set button 5 times and tell us what codes you see in the information center display. Do you see condensation or evidence of water inside the information center?
I didnt see any condensation in the info center and when I pushed the button 5 times it beeped and said end.. I didnt see any codes.
Well, I'm sorry to tell you this, but I've been down this road. I suspect you have water inside the information center. Information centers can be disassembled and repaired, but you have to be very careful.
I had pictures of my disassembled information center, but I can't find them since the site converted. In my case, the corrosion on the electrical connector was so bad, that one of the wires was only connected by a single strand of wire. I replaced the information center with a new one ($609.00), but I kept the other parts. This spring when I was getting my skis ready for the season, the other information center died; it is 16 years old. I used the old bits from the first failed information center to fix the second one, and it worked. The problem ... I put it together in my very humid garage. Once together, the water started to condense and puddle at the bottom of the cluster. That just happens to be where Sea-Doo designers put the electrical connector. So my gauge was going nuts and beeping like crazy by the end of my 4 hour ride.
I took it apart again, but this time I did it inside the house in the AC. I let it dry out for 2 days, and sprayed the electrical connections with DeOxit. For now, it's working perfectly.
Hope this helps.
