Shop Discount Sea-Doo Parts
2003 gtx di
jhjesse
Messages
2,673
Location
georgia
Water Crafts
2000 GTXDI 2002 RXDI
2009 RXTIS
Two 2001 GTXDI's
I adjust my rave valves all the way down and then back them up about 3/4 turn. My preference.
The WCV could be robbing you of the 350rpms you are looking for.
Not sure what other posts are referring to the bellows, but I have heard the WCV diaphram called a bellows before.
Down as little as 2psi on fuel pressure can rob you of top rpms. I would go OEM, but that’s just my opinion.
Is your TPS readings in spec? Have you peeked at the reeds?
jimmyluke
Messages
179
Location
Catawissa pa.
Water Crafts
2001 gtxdi,2002 gtxdi
Ok on the river flat spot gone nice hole shot but only 42 mph 6650rpm but still fun still the search goes on
Even if you are only getting 6650 rpm’s you should be getting more than 42 mph. One of my skis is a 2002 GTXDI which I believe is the same as your 2003 gtxdi. I also only get about 6600 RPM. It could be my low fuel pressure of 105 psi or a number of other things. But even at 6600 RPM I was only getting 40 mph on the speedometer. I did replace the wearing the previous season and my impeller to wear ring clearance measured about .012”-.024” but still only 40 mph. So my last ride of this season I tried two things. 1. Replaced the top hat and carbon ring/seal with a new heavy duty one. 2. Raised the OPAS steering vanes up all the way by using 5/8” shaft collars. Took it for a test ride-BOOM 50 MPH!! so I won’t know till next season which it was that improved my speed that much. I was not going to even try the new carbon ring/seal because I did not even notice water leaking there when I ran it with the seat off. But apparently you can be sucking air causing cavitation but not leaking water.
Happy new year! Jim
The Dazza
Messages
131
Location
Australia
Water Crafts
2003 gtx di
What is a top hat and where would I find it? And also please explain the second idea cheers jimmyluke
jimmyluke
Messages
179
Location
Catawissa pa.
Water Crafts
The “tophat” is a nickname for the part that I have circled in The first picture. It is also called a support ring. In the parts book it is called a seal carrier ring.It is part of the carbon seal driveline rebuild kit. All together It is a mechanical seal that keeps water out of the Hull and can also cause cavitation if the faces of the carbon ring or the support ring (top hat) are chipped or worn or do not have enough tension from the bellows (accordion boot) also in the picture.
jimmyluke
Messages
179
Location
Catawissa pa.
Water Crafts
Luckily I had a few pictures. The first picture shows the location of the carbon ring and seal components. The second picture shows the support ring (tophat) separated from the carbon ring. The third picture shows the factory support ring on the left and the new aftermarket heavy duty support ring on the right.
jimmyluke
Messages
179
Location
Catawissa pa.
Water Crafts
There are two paddles or vanes as they are called in the manual- on the back of your ski that are part of the OPAS (off power assisted steering) System. They help you steer the ski at low engine RPM and with the engine off. The paddles or vanes are held down by a spring and are supposed to raise up over a certain RPM due to water pressure from the jet pump(which I don’t know what that RPM is offhand). I was suspicious that my paddles were not raising up like they were supposed to and causing some “drag” and affecting my top end speed. So I disassembled the Spring loaded paddle assembly put a shaft collar on top, raised the paddle all the way up and locked down the shaft collar to hold the paddle in the upward position. I will find out next season how much this versus the new carbon ring seal assembly affected my top end. Mine(The paddles) probably were not raising up like they were supposed to because I can now notice a much favorable difference in handling at higher speeds. Hope this explains your question. Jim
jimmyluke
Messages
179
Location
Catawissa pa.
Water Crafts
As far as the 4 to 5 mm is concerned that it’s probably about normal. There is a procedure in the manual on how to check the accordion boot. You really need to slide the top hat back to check its condition. I’m not an expert on it but it does look like the top hat has some rust on the O.D so there’s a chance the face of the top hat is worn or chipped or distorted. Do you know how to slide the top hat back?
The Dazza
Messages
131
Location
Australia
Water Crafts
2003 gtx di
Ok so bought the rx di full fuel pump assembly to fit my gtx di looks identical apart from the how clean it looks compared to my original pump assembly. All oem and only $175 au dollars second hand and a perfect wiring loom. Installed tonight and fired straight up. I’ll head up the river on the weekend and try her out.1548923283809.jpeg
mikidymac
Moderator
Staff member
Moderator
Messages
13,777
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
Nope. You have to have the impeller tool.
mikidymac
Moderator
Staff member
Moderator
Messages
13,777
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
According to their chart it should be.
etemplet
Messages
3,223
Location
Louisiana
Water Crafts
1996 SPI, 1996 GTX, 1997 GTX
Read all six pages. I'm wondering how you guys are checking the fuel pump pressure? Where is the connection point and what kind of set up are you using? If I need to buy something I will. I have a few DIs and RFIs I'm working on. Help is appreciated.
mikidymac
Moderator
Staff member
Moderator
Messages
13,777
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
That is the anti-rattle pusher. It should have a spring on the narrow end.
The seadoo pumps use a thrust bearing system that can rattle at low rpm and even though it doesn't hurt anything people complained so this was seadoo's half hearted solution. Yes they still rattle.
etemplet
Messages
3,223
Location
Louisiana
Water Crafts
Miki I had a time trying to figure that one out. :) It fell out on disassembly so I didn't get a look at how it was installed. I played with it for the longest time and finally got it..... I think. Ha ha. I have to admit that is the dumbest design I've seen yet. Reading the manual takes all the adventure out of it. :) I have to admit though... when it is raining or late at night I sneak a look at the manual to make sure it's correct. :D
SPONSORED LINKS
Usergroup
