Bought the ski last weekend it runs great starts easy. It takes off good runs like it should but it will not exceed 30 mph according too the speedometer.
The spedo's are pretty bad but.....
Your ski should top out at about 45 mph but if it really isn't getting there you have a problem and shouldn't keep riding it that way.
Does it run good but just stops going faster?
Does the engine rev but the ski doesn't go like a slipping clutch?
I just bought a cheap harbor freight one for 30. I will get a better one tomorrow and re test. Unfortunately these dont have a rpm gauge. Also it started very easy no choke either. Just trying to decide if this is going too be a ski worth trying to fix or just sell the ski.
I question the gauge for two reasons. One... if the ski starts in the water when hot compression is higher than 90 psi. And Two, I went to purchase a ski and the seller wanted me to use his compression gauge so I did. I got 90psi and told him I didn't want to ski.. Then I tested with my OTC gauge and the compression was 145. He was shocked. What made me retest with my gauge was that I asked if the ski started well in the water and he said yes.
Personally , I like doing top ends before they do any carnage to the engine. Bring that baby up to spec and a little pep in the step. But if it isn't need it isn't needed. Good Luck
