Old but not tired
Two years ago I took it to the dealer for a tune up. It came back blowing fuses (see previous posting). Dealer was no help. It was out of the water for two years.
Finally solved the fuse problem and got the SD in the water. Started fine but would only rev to 3350. Wide open throttle. Tried three different keys. Replaced plugs: had newer plugs in and tried older ones, no difference). Smell of gas is noticeably more than I remember.
Any suggestions?
UPDATE: out of the water it will do 4500 RPM.
IF there is already a thread on this, please point me in that direction, I did search for the last hour but found nothing similar enough.
Any suggestions?
