LakeSki1225
Hey guys, so I bought this machine back in May with the top end already out of it. Brief history on the ski is that it sat from 2010 until 2014 when the PO that I purchased it from bought it, the PO then said he had it out running on the water last fall and he lost a cylinder. The PO said that he believed it just needed a top end rebuild, seeing as one of the rings was smashed and piston was grooved up pretty good. So being the optimistic person I am I purchased the ski and got right to work. After removing the engine and splitting the cases( because I also am paranoid and want everything done right and super clean) and doing a bit of research I found that the pistons were already bored over to the max( last rebuild in 2010 by SBT) and had to be re-sleeved and put back to std bore. I also decided that for as long as it was sitting and seeing as how I had the cases split to just go ahead and do a complete rebuild on it.
Next I sent everything out to have it re-sleeved and completely rebuilt with a new crank and the whole nine yards. A few weeks ago I got all the parts back and began cleaning everything left in the machine and getting ready for the reassembly. I drained and cleaned the gas and oil tank. New oil lines and filter (primed). All new gaskets everywhere. New pistons, re-sleeved cylinders, and a new crank. New o-rings on RAVE valves. Cleaned and tested all injectors and they all worked fine.
So I spent all of Thursday this last week and both Saturday and Sunday putting every single thing on the motor back together, making sure to follow the shop manual to the last detail because as I have read about these machines they are a huge headache unless things are exactly as they should be. Late last night at around 1030 after a very, very long day and a long time waiting, it was finally time to put gas in it and give her hell, the first attempt to start it since buying it in May. Well seeing as I am writing this you can probably guess how it went. Upon pushing the start button, it didn't start. When I put the key in, it beeped twice, as all machines do, then the display was displaying low fuel because there was only about 2 gallons in there and the red light was flashing, it also sounded like maybe the fuel pump or something was running briefly, then I pushed the start button and nothing at all happened. There was a few quiet short clicks coming from back by the battery area and then nothing. So now I sit here wondering what the next step is, and ANY and ALL HELP is very accepted at this point in the project.
So now I have no idea what to do or where to begin. I know I bought a project and I understand that comes with some unknowns but if the previous owner wasn't lying and did actually have it running then I don't know what could have changed to make it so now it wont even turn over. I will say that I have NOT bought a new battery for it yet, however I had the old one trickle charging and on my charger it was reading close to fully charged. I suppose it could be that and just not enough voltage is getting to turn the motor over, but right now beyond the battery I don't even know where to start. We leave for a week at the lake this upcoming Saturday and any all HELP would be greatly appreciated as I am really trying to get it running by then. Please HELP guys, I know there are some pros to these skis out there and I know there are tons of people that know way more about these machines than I do. Ill take any HELP I can get. :facepalm:
Thanks
Thanks
