Last year my exhaust overheated and melted the rubber transition hose (between the exhaust manifold and water box). I have replaced the high temp exhaust hose (about 4 inches long) that melted off; however I need to make sure I fix the problem that caused the overheatng of this area. I took the water box rave value appart (was told to check this first) and didnt notice any issues. What should I do next to confirm I will not melt down again. Is it possible I just sucked up some debris that has cleared and I am good to go. When I run it I see water coming out the jet and two other places at the rear of the ski (upper deck stream and right side rear stream).
Also in addition to the hose mentioned above that was replaced I have another hose 3/8 inch or so that is t-ed off the hose that goes to fuel vent system solenoid that runs down to under the engine (it was melted off). I have ordered a replacement hose but can't see the other end. Please tell me I dont have to pull the engine or manifold to find the connection point; any help/advise you can provide is appreciated.
