NS, It seems if you take out the front storage basket, then the front air intake, then remove the steering assembly, you can get to the fuel baffle assy in the fuel tank. This according to the manual. Here is the VTS test for the motor and the module;
Always confirm that the fuse is in good condition. The7.5 amp fuse is in the MPEM module. Check the motor with a multimeter. Install the test probes on both the Blue/Orange and the Green/ Orange wires. Resistance should be close to 1.5 ohm.
If the motor seems to jam and it hasn’t reached the end of it’s stroke, the following test could be performed.
Remove the motor from the VTS. Manually rotate worm gear to verify the VTS for free operation. Connect it directly through a 15 amp fuse to a 12 volt battery. Connect wires one way, and then switch the polarity of the wires to see it work in the other direction. If it does run in both directions it could be the VTS module. If the VTS motor does not stop at the end of its stroke then the motor could be defective.
The VTS module receives it current from a 7.5 amp fuse in the MPEM.
Disconnect the Brown/Black wire and the Brown/White wire from the VTS module. Connect the probes of the multimeter to the 2 wires of the module. Push the start stop button to activate the MPEM timer,(gives power for 33 sec. without running engine). Push the VTS switch down position until motor stops. The ohm resistance reading should be 24 ohms+-1%. Push the switch button up until the motor stops and the resistance should be 167ohms+-1%. This test isn’t perfect but it should be close.
If you want you could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and privet use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too.
Karl
