I have owned the boat for only a few short months. Have not had any issues until the last couple days. Took it out on Saturday and battery was dead at launch. Took back home and put a booster on it and tried starting it with hose hooked up and running to flushinc connector. Wouldnt do the trick. Took back to the launch and jumped it with a set of battery cables. 5 minutes after getting the boat running I realized that I didnt close the flush connector cap. There was water coming out of it with the boat running. Ran fine for a couple of hours, and then took it back home.
Next day hooked it up to a set of battery cables on a vehicle before taking it to the lake....hooked up flushing system and boat cranked over fine. Headed out to the lake.
Started just fine at the lake. As soon as as i started to accelorate the warning light/beeper was going on and off. But not the normal sound of the beeper. almost like a faint screaching sound that you couldnt even hear when the boat was at high rpms. Sounded like something would sound when the batteries are dying. (just an anology.) Shut the boat off to read my manuals for about 15 min. Attempted to re start the boat, and it wouldn't even crank over. Is this an electrical issue? Do i need a new battery, battery looks new. This is my first boat, so any help would be appreciated. Would leaving the cap off the flushing connector with the boat running hurt the engine or cause water in any of the filters? Thanks in advance for your time
