2000 Seadoo Challenger 240efi Mec engine
Messages
13
Points
16
Location
Scotland
#1
Hi guys, I have a Seadoo challenger which has been a awesome boat for Loch Lomond. It's been running great, new plugs, fuel filter etc all before going in the water.
Yesterday it was starting and running fine, used it for around 2 hours towing. We tried pulling another skier up when we encountered the problem. Trying to pull the skier up, rev'd fine then began to miss fire which wouldn't clear. Shut the engine off and tried again, which the engine again Miss fired. We changed all the spark plugs, still missing on acceleration and throttle.
The engine starts and stops fine, runs fine on a low rev but when trying to accelerate begins to miss fire and will not rev or clear and speed up.
I have ordered new ignition leads in case they are breaking up or faulty.
Any other help would be greatly appreciated, thank you in advance.
Steven Williams
Messages
101
Points
18
Location
Hub City, TN
#4
Sounds like your misfire might be caused by the mystical Throttle Guardian. Do some searching on here for it. I remember one guy had a write up with a picture of it and how to remove and bypass it. It was a safety feature not found on the wiring diagram that cuts out spark to the engine. I believe it's a small black box found behind the steering wheel on most boats. Good luck.
poppie
Messages
1
Points
1
#6
Probably the trigger coil located under the fly wheel. The manual specifies how to check it. Also do a visual check of the wires. The wire insulation frequently goes bad.
Users who viewed this discussion (Total:3)
Latest posts
Adsense
