I bought a 2000 seadoo rx that has a carbed motor and its a reed case engine not a rotary engine. I would like to know if I could still do the OIL PUMP BLOCK OFF KIT! I have tried to find info on doing it to a 951 motor but cant find any, Can this be done? If so where do I leave the oil line to lube the crank? Theres one nipple on the lower block right by the exhaust and thats water right? Then theres 2 nipples under the carbs ones for the rave valve aand other one going in to the carbs right?
