Ok I decided to pick this project back up again tonight given Memorial day has me in the boating spirit. I rebuilt the carb one more time, cleaned it all, tested pop off (32 psi), put in fresh gas, and gave it a go. Seadoo still doesn't run properly. I am having a lean condition because I can make it idle but the choke needs to be about 7/8 closed to make it run (idle). I have played with the low circuit needle valve (1 to 2 turns backed out) and no change. It appears to have fuel since I can see the accelerator pump squirt fuel into the carb throat for 2-3 strokes after I shut it off. What could be wrong with the engine that would allow air into the combustion chamber causing a lean condition assuming the problem is not in the carb? What steps would you recommend to further diagnose?
