Hey everyone,
First time poster here, hoping I can to the right place for some help. I recently inherited (2) 2000 GTI's that had been in the family for years. So here is the backstory -
Ski #1 - drained fuel, drained oil, installed new battery, turned engine over with plug removed, replaced plugs with new ones, added fuel & oil. Ski fired up after a little cranking (in water). Took it on a test drive, ran good and was able to open it up full throttle with no issues. I slowed down to turn around and when I went to accelerate, the ski would go bog down real bad, but never did die. When I would let off the throttle, the ski held at perfect idle. Assume this is a gummed up carb issue, but curious if there is anything else to check? Also, how hard is it to clean the carbs? (fuel valve fully turned on)
Ski #2 - drained fuel, drained oil, installed new battery, attempted to crank ski with plugs removed, and got nothing when I pressed the start button, no beep or red light. I went back to inspect the battery and confirm everything was connected correctly, it was. I started looking around the batter and noticed a plastic box (w/seal) directly in front of the bar tray. The top of this box was loose and i was able to pull out the electrical connection - not sure the correct name for that part, but it appears to be the ignition or something along those line. Anyhow, when I pulled that part out, the terminals on the bottom were completely rusted - assume that is why I am not getting any crank? Before I go throwing parts at this thing, looking for some input. What is that part called? Can they be salvaged? How much do they cost to replace? Etc.
Thanks in advance!
- Both skis hadnt been started in 5/6 years
 - Both skis worked when winterized and put away
 - Both skis sat outside, but under a covered carport
Thanks in advance!
