I have a couple of things going wrong with my boat. Fathers day was the first time I took it out this years. As soon as I left the ramp area I noticed it took longer than usual to plane. Once it finally planed it was smooth sailing, top speed felt the same. Then I sucked up a few medium size rocks, 2-3 inches. They went into the driver side jet pump, the boat was really shakey. I shut it off and later tuned it back on. The banging and shakey went away. I trailered it and inspected, I have two rocks wedged in the outer part of the jet. So I have looked threw the threads and read up a bit. Seems like maybe a wear ring could have been causing the "cavitating". But now that i sucked the rocks in I will probably need to replace the impellor. Since I have to replace on impellor might as well replace both and upgrade. So I am looking at two wear rings, two impellors. My question is what impellor would be best, and what else should I replace while in there, is there anything else that might be causing the original cavitating. I want to do it right I want to do it once! Thanks for any help you provide.
