whealy22
Hey Guys. First i just wanted to say thanks for having this forum. I'm hoping you guys can help me out!
So i am having a really odd issue that my friend and i just cannot get to the bottom of. The starboard engine seems to have intermittent spark. Here is what is happening: When we go to start the engine it starts but then dies on it's own after a few seconds, then it's very hard to start at all after it gets up to temp it seems. Even if we give it full throttle it still doesn't want to start. Sometimes it just starts up for a few seconds but then dies out. When it does run for that 3-7 seconds it doesn't seem to want to rev over 3-4,000 RPMS. It also does backfire after trying to start, which we both found odd. Compression is 148 in each cylinder and we did verify it will run on both cylinders when it starts for a few seconds but then dies out on it's own. Here is what we have done so far to fix the issue.
We replaced the pick up/trigger and while we were in there inspected the stator and housing. It was very clean in there. So we did not think it was the stator. We also replaced the spark plugs, spark plug wires and coils, we disconnected the red wire to the rectifier and tried running it with no change, we disconnected the 3 connectors on the MPEM, inspected them for corrosion and did not see anything and then put dieelectric grease on the connectors and reinstalled them, also cut the spark plug wires back 1/4 inch and reinstalled them. We could not see spark while checking the plugs for spark but yet the engine does try to turn over and start from time to time but like i said will not stay running. Also we checked the 2 fuse boxes below the MPEM and all good, we have gotten down to thinking it's the MPEM but they are soooo expensive if that's the issue i could be out for the boating season...
The other engine starts and runs fine.
Anyone have any other ideas? Is there something we are missing? If it is the MPEM does anyone have a cheaper or less expensive way of getting an aftermarket one or does someone reliable repair these units?
PLEASE help. lol. Thanks so much!
