LIBoater
I have bitten the bullet and I’m going for a top-end rebuild… I’m sure many on this forum have done this 100 times, but it’s a bit daunting for me… so a couple of questions:
1. Where do you recommend I go for the rebuild kit and to have the heads bored/refinished?
2. Assume I should send the rave valves in with the heads to get them shaved as needed?
3. Similarly assume I should refurbish the rave valves while I’m at it? Same question as #1, where should I source a good refurb fit?
4. I have the heads removed, but the piston retaining clips are pretty stubborn (could be my (bad) technique?). What is the best way (tool?) to remove the old and install the new?
5. Any other “gotchas” I really need to watch for? Gasket kits? Gasket sealer (I read that the great stuff is best?)
A lot of questions, as always… appreciate, in advance, the support from the brain trust here! Thanks.
