jumphighest
I just purchased my first Seadoo as a project. The PO said it worked fine before putting it away for the winter. It only clicks once when I push start. Tested the battery with a multimeter and it reads fine. It does drop from 13.5 to about 9 when I push the start button. I tried replacing the starter relay; no dice. I also jumped the terminals of the starter relay and I would hear a single click and the wire I used to jump the terminals would get extremely hot and try to weld itself to the terminals. I pulled the starter and bench tested it; it spins freely when connected to a battery. That means it must be good right? I'm not sure how much torque or how to even measure if it has enough torque to start the motor.
I'm going to reinstall the starter and then pull the spark plugs to see if the engine will turnover then. If not, I'll try to spin the drive shaft with a wrench. Honestly, something I probably should've done before pulling the starter motor...
Do you have any further advice or thoughts for me to try?
