Picked up this ski recently with a stripped starter and bendix. Replaced both of those as well as rebuilding the carb and replacing all the gray fuel lines. Admittedly I used a cheap rebuild kit, but after doing research trying to solve my issue I’ve ordered an OEM kit and will be redoing them. The carb was terrible, worst I have personally ever seen. While I am newer to PWC I have a lot of experience with 2 stroke snowmobile engines. The problem I’m having is that the plugs are soaking wet in what appears to be oil. I can pull plugs and add a small amount(2.5 mL) of gas and it will fire for a small amount of time. Spark looks strong as well. Oil pump lines are matched up. Could it be I’m not getting any gas and it’s just oil coating the plugs? Or it is possible the PO with how bad the carbs were continuously cranking flooded the case with oil and it just all needs to burn out? Looking for suggestions. Manual and carb kit will be here next week. Thanks in advance
