Hey all - I think I'm in a world or trouble!
Boat is a 98 85HP single sportster.
Last year before packing up the boat I had all sorts of trouble getting it to plane; felt like the propeller was slipping and it would simply "spin out". After doing some reading I figured it must be the impeller / wear ring. After waiting two months here in Alberta (and all sorts of excuses from the dealer) - I was off to the lake $1100 dollars poorer
Got it in the water with much excitement and let it warm up for a few before giving her some throttle - and nothing improved; infact, it seemed worse. After a few minutes of feathering the throttle I couldn't even get it up (lol) to plane as before. Frustrated I revved her up high for a couple seconds - when she suddenly bogged out and died.
Worried I might be paddling back to shore I put her in neutral and throttled right down - started and purred like a kitten. Popped open the rear access and looked inside to see water spraying from a number of places...
I apologize for the artwork I noticed that two of the exhaust header (red arrow) have sheared off - and a ton of water was spraying out there; I had a pinhole leak squirting off the small black plastic line on the exhaust (green arrow) ; have what looks to be a missing bolt - or perhaps nothing (purple arrow) and could see water ebbing in on the hull around the driveshaft (blue arrow).
Needless to say I'm fairly frustrated at this point - I do have some mechanical skill and knowledge but seadoo boat functions are pretty foreign to me - hence paying all that cash for the new impeller and ring @ the dealer.
I guess I am looking for two things as I didnt notice these before -
1) Could the driveshaft leak been caused by the mechanic changing the impeller and wear ring?
2) What the **** should I do about the exhaust? Could this be the problem causing the slipping; Where should I start looking?
I cant afford to spend anymore cash on the boat and with the summer almost over here in Alberta I have a couple very dissapointed little boys that were looking for some summer fun. Any help and suggestions would be greatly appreciated!
Thanks!
Shawn
Thanks!
Shawn
