Spoonchucker
Still waiting on my manual for the boat off of Ebay - hoping someone can answer this:
So the thru-hull ABOVE the swimstep on the starboard side is for........? Guessing that it is the pee-hole to let you know that cooling is circulating? The hose is clamed on to the thru-hull but then just laying down in the boat - where does the other end go and why isn't it peeing water into the bilge (maybe it is? - only had it on the water for about 1/2 hr total)
The bilge pump is plumbed to a thru-hull UNDER the swimstep. (That all seems to be A-OK)
Also - at the top of the oil tank are two hose - one larger diameter (1/2" maybe) and a another smaller one (1/8" ID?) - the smaller one does not go anywhere - plugged off about a foot from the tank. The larger one is full of oil and goes down to a split then off to.....looks legit. What is the smaller one for and where is it supposed to go?
Thanks
SC
Thanks
SC
