Scrapy
I just purchased a 1998 Speedster. When starting the engine cold, it's really hard to start them; specifically the right one being harder to start than the other. Once you get them going, they run great when your going at any speed above idle. Once you bring them down to idle they frequently stall. I just took them into a local guy that rebuilt the carbs but that didn't solve the problem. He also was told that it might be a problem with a plate that sits behind the engine or a gear gone bad but when he checked that, that wasn't the problem either. I also had a compression test done on both engines and that checked out ok. Also had fuel filter replaced and spark plugs were replaced last year by the previous owner. Oh, and had the RAVE valves removed, cleaned and replaced o-rings. Any ideas?
