VERDUGO135
So I decided to tackle this project on my own. At first I was a bit intimidated but most shops are backed up and I don't want the summer passing by. So long story short bought the boat missing complete port side engine and accessories. Bought a 95 xp and pulled the engine and all necessary parts from that ski and dropped it into the boat. Soooo first thing, the muffler/exhaust fits, although its not the correct muffler for the boat. Aside from not being the correct muffler is there any reason why I can't use the xp muffler, ie; performance difference between both engines? Next question is the carbs, thats where I'm really stuck. The original starboard engine has a single carb. The xp engine has dual. I'm guiding myself off of the starboard engine as I install all the hoses but both carbs are completely different. I have two hoses but there is only one input on the dual carb setup unlike the single where there are two inputs. Also which hose goes where? I've included some pictures, thanks in advance for your help.
this is the starboard engine with original single carb, you can see the two hoses connecting into the carb
here is the port engine which im installing, the carbs are dual and there is only one input, or so thats the way it was on the ski. i drew in some numbers for easy viewing.
Last thing is if anyone knows where the oil pump is on these engines. Do I only have one pump for my boat and where can I find it? I want to make sure its working properly. The previous owner had no idea why his original port engine blew a rod I want to make sure everything is in ship shape before I take it out on the water. Thank you.
