To put this back on topic... (He asked about a tube, and not a debate on twins)
The Sportster with a single 720 engine WILL pull an adult on a tube. It will also pull up an adult on skis, or a fat wake board.
BUT..........
1) It has to be in good operating condition. (that's the key) If you have a pump that is questionable... or a leaking carbon seal... you won't go. There's a lot of guys here that say the single is useless... but it's not. They just get their opinion playing in a poor running boat, or just make up an opinion based on no real personal experience.
2) DO NOT EXPECT TO HAVE A HIGH PERFOMANCE RIDE !!!!!!!!!!!!!! Yes... you can pull a small single tube, and get it to whip with a +200 lb adult on it. BUT, you won't have much fun pulling a big (2/3 passenger) tube. It's just too much drag. Also... of you have someone on a ski or wake board... they WILL pull the boat when they cut. (regardless of single or twin) Along with that... if you have 3 large adults in the boat, with a large adult on the tube... it will be slow.
The big issue here is drag. The 14.5' boats are only rated for 649 lbs. SO... if you have a 250lb passenger on the tube... then the other 3 people in the boat can only weigh 100 lbs each. More than that... and you are over loaded !! This is regardless of a twin or single. Oh... and you have to subtract from what the people weigh, if you decided to bring a cooler, tools, or anything else. Lets face it... 2 adults, and a small kid can put it over weight.
Anyway... the point to take here is... it's a little boat, and you have to treat it as such. But, since it is small... it's easy to deal with... and the expenses are less. I agree 100% with the guys above about fuel. It's a boat, and you have to feed it. But, I don't agree with the "2 engines don't cost more"... because they do. I've never seen one of these boats that when something goes wrong with one side, that the other side isn't far away.
I had one of the singles for several years... and it was great. So, I speak from experience when I say... it will do everything you want it to. BUT... if you want to have a 50 mph, high adrenaline tube ride... then you need A LOT more HP. If you want to have fun and get wet... then it will do just fine.
