Ok so I have a 1997 XP that i've been rebuilding this winter. All new everything (new rave bellows, cleaned raves, fuel lines, oil lines, fresh oil, motor aligned with tool, new aqua torque starter, etc). I've cleaned all the connections while the motor was out. All connections are clean and I've coated them with dielectric grease. I finally got a new and fully charged AGM battery. I put the key on the dess post and I get no beeps. I can however push the start button and the engine will turn over but I get no power to my gauges. VTS unit is shot so that it disconnected. One thing is that I have a multifunction gauge on my 97 XP. I've done a lot of searching and I dont think I've seen anyone with the multifunction gauge on this model. I've only seen the analog fuel gauge stock on these skis. I noticed that there is a connector on the multifunction gauge that isnt connected (tan wire with blue stripe and a purple wire) but there is no connector to hook this up from the mpem. Any ideas with that? Could that be why I'm not getting power to my gauges? Anyways, here is a summary of the things I've checked with this ski.
-Checked mpem power pins and supplied a 12v source to pins 24 and 26 and the 5amp fuse did not blow (according to the test on seadoo source).
-fuses on mpem are good (15amp and 5 amp fuse are good and do not blow when power is added or trying to start)
-Plug key into dess and no beeps but the motor does turn over just fine
-took buzzer out and tested it with a 12v battery and it does beep
-new AGM battery fully charged
-checked connections in rear electrical box and everything is clean and greased. 15amp fuse is good and not blown.
-all connections from battery are clean to the motor.
-multifunction gauge has 1 2 pin connector not connected (tan w/ blue stripe and purple wire) but 4 pin connection is connected
-VTS is dead and all connections are disconnected and removed 7.5 fuse.
What else can I be looking at? MPEM should be ok if the engine turns over right?
