dgoodwin10
After a test ride I now have a to-do list and questions I need some help with, so here goes.
During my daily Craigslist searching I ran across a 97 SPX for $650, which didn't stand out too much until the next picture on the ad revealed this:
Needless to say, I had to have it given the goodies on it. Come to find out the guy was super cool and was a former racer that had plans to build a modded rec boat but had lost interest in this project. Aside from what you can see it had an original motor, rebuilt carbs, all gaskets to reassemble, ProKs, rebuilt pump, 96 XP Ebox, cart, trailer, spare XP hull and another single gauge hood .
After giving it a good once over, I reassembled everything and took it to the lake today.
The only issue I had was a leaky exhaust gasket which I patched with electrical tape and a coke bottle to get by for the afternoon. Because Roadkill (if anyone gets that reference)
Overall it ran really well, save for a stupid high idle speed that needs to be fixed. The only 'odd' noise it made was a slight chatter after I let off the throttle, which I think could be a result of the high idle speed. Is that something I need to be more worried about?
I do plan to put an impeller, grate, sponsons and mats on it, as well as swap the fuel/oil gauge for a XP info center and add a grommet to the UMI base.
I'd also like to add a tach as well- does the MPEM even support that to use a factor piece or will I have to go aftermarket there?
