SpeedsterRob
Hi All!
This is my second post! I recently picked up a 1997 Speedster with one blown motor because I just wanted to do a little tinkering I guess :facepalm:. Its been a long winter and I thought the price was right and the wife wasn't threatening divorce so I hauled her home.
I've been out of boating for a few years. My last hole in the water was a 1988 Luhrs 342 Tournament that I co-owned with my Dad (he is the one who got me into boating in the first place....not sure if that is a good thing or a bad thing). That was a pretty good boat though as I owned it from 2004 through 2011.
Now onto my next adventure :banghead:.
The port motor starts and runs pretty good. It is the stbd motor that I knew needed to be rebuilt.
I started stripping down the motor the weekend of 5/17/14. Prior to this I tested the compression and got about 140+ on the mag cylinder and about 30 on the pto cylinder. It appears that the pto piston threw its wrist pin c-clip (rear most) and this bounced around a bunch and pretty much 'stapled' the rings into the piston. I'm not quite sure how this happened but at one point the pto cylinder cracked (outside wall) most likely do to freezing/expanding water and maybe this tweeked the piston and 'un-seated' the clip. The cylinder in question had been repaired (at least to keep water from leaking).
I purchased a Cylinder exchange kit from SBT at this point believing that this would be the quickest way to get me on the water (it was my hopes at this point in time to be up and running by Father's Day :driving
The Cylinder Kit went in pretty good the following weekend (5/24/14) and she fired up! Now, prior to putting the pistons/cylinders back on I did indeed ponder whether or not I should pull the whole motor and crack the cases just to make sure all of the c-clip debris was removed. Of course I did not do this...and I jammed up my rotary valve and stripped by brass gear (the brass gear could have been previously a little stripped though - not sure). Anyways, this all happened late Saturday night when I just got it back together and then it seized when I put it on the hose the next morning....
