marke52896
This Ski (97 GTX) is causing me to loose my mind. Had early issue with carb which thanks to this forum I was able to solve (pop-off pressure wrong after rebuilding card) but that was corrected. Ski ran fine for one nice long ride on the lake the next morning she would crank but not turn over. Fiddled with it a little more and got her going, first ride I hit a small wave and she died and would crank but not fire. Switch the ignation coil and starter relay from working 96 GTX and the 97 fired right up. Put the ignation coil and starter relay into the 96 which was running and it would not fire so I replace the coil and relay and the 96 fired right up. So I thought I had solved the problem. Decided to retest the 97 and she cranks but will not fire even tried switching the coil and relay and still will not fire. How could it work one day, sit on the trailer for 3 days and them nothing? Spark is weak and the plugs do not appear to get any gas? About to make this ski a fish habitat.
I have checked the 3 fuses I could find (one where coil is at and two in front), replaced the regulator (I think thats what it's called) located in front. Nothing????
