To make it simple, was there anything wrong with the old boots?Darn. Is there a recommended non resistor plug I can swap these out with then? Or should I keep the plugs and find some different boots
Great info, see us old timers can learn something too.OEM Spark plug boot part number for you SD is #278000237 wich will show up to be a NGK TB05EM part, a resistor-type boot. Spark plugs are ALSO resistor-type BR8ES NGK. Resistor boot AND resistor spark-plug setups are not that common but that's the factory setup. Would strongly advise against using either a non-resistor plug or boot on any Seadoo. (But if you insist on doing it, please tell us how it went).
It controls spark advance and whatnot but it gets the clue on when to fire the spark plugs from the trigger coil (a far simpler and cheaper component that you should be testing)The MPEM box controls spark right?
