BoaterCycle123
Hello,
This site has been extremely helpful and I am grateful for everything everyone has shared with me thus far. I wanted to address another issue that I am having with the carbs. Just a little history on the machine. I bought the machine with a rusted crank and have rebuilt the motor from the ground up.
After that rebuild, I started the engine (After some spark timing issue, in another thread) and the second that it starts, it revved to around 4000rpm right off the bat. The only thing that slowed it was pulling the choke.
So naturally, my first move was re-build the carbs. I completed that and now it Revs right up to Max RPM as soon as it starts. So the carb cleaning worked as it is revving higher than before! Perfect! However, this still does not fix why it is stuck at WOT (wide open throttle). The only parts that I did not mess with on the carbs were the High-end and low-end screws. I am going to take my best shot at those tonight to see what the issue is. It does not like like anything is missing from the carbs compared to the carb cleaning how-to. I did not check the pop off pressures either. they seem to be getting plenty of fuel though.
I have done an oil pump bypass, could an air leak after the carb cause this? I plugged the old brass nipples with Marine JBWeld.
I have also checked the throttle cables and everything related to the throttle and it is all operating well.
Anyone had this issue or know what the fix maybe?
TIA
TIA
