shattered00
Today I tried to remove one of my 787 engines so I could get to a stuck starter screw and to prep the engine for a rebuild. I had removed the 95 xp without any major issues and figured this would be similar since it was a related engine. I now feel that I have bitten off more than I can chew and screwed up a bunch today.
I got the engine unmounted and loosened all of the clamps on the driveshaft boots. I screwed up and removed something at the front of the engine towards the mag side and oil poured out everywhere (pic 1). I removed the jet pump and then tried to remove the impeller housing but it would not budge. I also pulled the cone off of the impeller housing thinking that I had to remove it and oil poured out of that onto the ride plate, me, and the garage floor before I could get it back on.
I then found out that there are two homemade tools used to remove the impeller housing that are referenced in the Clymer shop manual. I found one of them online for $140 on ebay in Canada, but that seems pretty steep. I then searched and found either the "tree" method or the "2X4" method.
Question 1) Are the OEM clamps that I removed from the driveshaft boots replaceable with the screw on type that are so much easier to deal with or do I need to use the OEM clamps when I replace them?
Question 2) Would y'all recommend buying this impeller house removal tool since I will have one more ski to use it on assuming it gives me as much problems or should I use the 2X4 method?
Question 3) If I use the 2X4 method, do I cut it to where it just touches the beginning of the black exhaust port on the hull (from side to side) and use smaller cut 2X4 pieces as spacers since I don't want to go through removing the cone again? Also, is it okay to have only 2 holes in the 2X4 or do I need two 2X4s so that I can reach all four holes where the jet pump would normal screw in (for equal pressure)?
Question 4) Pic 2 is of something I found in the bottom of the hull before the oil spill. It broke off from something from a prior owner. Any ideas as to what it is?
Question 5) Pic 4. Did I remove everything I need to in order to pull it out once I get the impeller housing free? I have not yet removed the three hoses behind the VTS per the manual, but I will.
Question 6) Pic 6 and 7. This plug fell holes first into the oil. Oil is now blocking a few of the holes. Is this plug ruined or do you think I could clean it out?
Thank you for any help. I do apologize for the excess questions. I feel absolutely overwhelmed, but I really want to get these skis up and running before summer with at least some semblance of cleanliness internally. Maybe I am aiming too high and should just focus on getting them running first. I did take pics of everything before disassembling but there are so many more parts I am not sure that I will take it down to the bare hull even though I know I need to because of the oil.
