robertmetalman
Hey, I have a 96 spx and my gauges stoped working. I have 12v and ground going to the fuel gauge and from what I can tell the trim gauges gets its power from the fuel gauge from a purple and black wire that leaves the fuel gauge and plugs into the trim gauge pig tail. I also straight wired the trim gauge with 12volts and moved the trim shaft manually because my trim motor went out so i had it off while doing this test. My VTS seems to be fine, I replaced it last year and the two wires going to the motor will reverse poliarty when I press the up and down trim button. But still nothing comes on on the fuel, oil, temp, battery gauge. Does this sound like the gauges are bad. can any one point me in the right direction.
