Someone said..... if I needed some help figuring out where things go on the SPX..... Well I got a cooling water line I need to connect. It's on the exhaust pipe all by it's lonesome. I checked the fitting that connects to the engine under the exhaust pipe and it is not a "TEE" I've seen a few fittings like that. I can't see any other place wher this one would connect. It's gonna be rough if I gotta pull that off with the exhaust system on there and I'm not removing it. Forward..... not backward..
I did look at the diagram but can't see with enough detail. Help is appreciated
