I removed the head and the cylinders measured well within tolerance. Looks to me like a large section of the top ring is missing on the PTO cylinder. Seems strange because there is no damage in the cylinder. Approx a 1 inch section of the top ring is missing.
I want to remove the cylinders but the exhaust manifold will be a bear to remove. Why do they jam the bolts in there in such a way? What is the best way to remove the manifold? Pull the cylinders with the manifold attached? A little insight would be appreciated.
I already made a short allen wrench for the job but it won't be easy.
The jet ski ran fine with only a minor issue not related to compression. I removed the head as a result of other minor work.
Thanks in advance !!
