Oil line is still leaking, seems like the end is too stretched to make a good seal with the new oil filter, going to have to take the line off and try again with a hose clamp.
other news, finally got to work with the cosmetics, I think I did pretty well so far, going to paint the hood of the ski and leave the rest gelcoat.
Here's what I started with in the rear, still had the decals in the footwell, and all the old adhesive and rust stains too that needed to get taken of.
Started here with the white, wasn't as bad as the rest so only wet sanded with 2000 grit and then buffed and polished to the finish it has now.
Towards the end of the ski I had to get more aggresive with the wet sanding, using 1000 and then 2000 grit to get most of the staining out as I could, followed with compound and polish.
(There's some of the oil on the floor too, used some degreaser to get it out as best I could will do a more thorough cleaning when the leak is resolved.)
Here was a little more challenging, oxidation was a whole lot more noticable, wet sanded with 1000 grit, went through the side of the hull twice, followed with 2000 grit which I had then made four passed through, finished with one pass of 3000 grit on the DA, the whole process took about two hours to do so.
What it looked like after the first pass along the side.
Went through with the compound twice with a wool pad, and then twice with polish on a finishing pad
Applied a coat of wax which I plan to do on the entire ski, let to sit on the gelcoat for a couple minutes before wiping clean with a microfiber cloth.
Planing on wet sanding and getting the finish on the underside of the ski tomorrow too, along with finishing buffing and polishing the other side of the hull too, needing to wax the entire ski once I finish all that.
Leahter conditioner works very well on faded plastic too just in case anyone needing any help with theirs.
Was wanting to order the decals, seat cover, and mats tomorrow but with the whole coronavirus situation going on apparently people like hydroturf have to close up shop temporarily? If that's the case should I just wait till it all blows over before ordering?
