rockstar2015
Here the background information- acquired jetski ( 1996 GTI ) said it was winterized 2 years ago, Decided to see if it would even turn over. Got new battery turned over and after a little bit it fired and ran but had some oil coming out of exhaust... Being it has sat for a while I wanted to do a carb job because I know it needed it as I have now found it it has never had one done to it
Drained out the gas( lots of water...) Rebuilt the carbs and installed a new filter as well as gas lines as I have read the gray needed to go. The gas lines have been "purged" to say the gas is into the carb
Got everything back together tonight-the Carbs are getting gas so thinking it isn't this
Also it beeps twice when I connect the DESS.
NOW:
The jetski will turn over and over and over no issue and very strong but it isn't firing, decided to check the spark, It IS creating a spark but it is very weak IMO, pulled the plugs and they are somewhat wet... I know it will run just not sure where to go next, Already cut back the wires and new plugs. Pulled the engine cover by flywheel to see if there was corrosion but nothing there
The engine appears to be very clean and good compression
Thanks for the help in advance !!
NOW:
