1995 seadoo xp question
eng50ine
Hey guys,
a few days ago i posted how i keep blowing fuses. After research i just ordered a new MPEM, but my question is, will i also need a new VTS? The stator is fine (i think). The VTS has 3 plugs under the dash in the bow of the boat right? If i do need a vts will i need a motor and electrical components or just one or the other? Keep in mind this happened after the engine compartment filled with water, which (i think) caused the vts to short out and blow the MPEM. Does this sound correct? Any help is appreciated, as i am a new Seadooer.
Thanks,
Brian
In your VTS... there is a controler. If that shorted out... you need an entire VTS. If the motor is frozen... you only need a motor.
Did I talk to you before about a used 95 VTS? If I did... PM me.
